keying blendshape weight for each curve's ep / query graph attribute
Message 1 of 1
I need help with 2 matters :
1. keying blend shape weight for each curve's ep :
I blend shape from 1 curve to another. I want to set blend shape weight for each edit point. What command do I use to do that? I tried to key blend shape weight through component editor. However, even with 'echo all command', nothing appear in the script editor.
2. query graph attribute :
This is attributes in hair system :
I want to query graph attribute and save it as text file to use it later. I have no idea how and where to start.
Thank you,
Bird,
Replies (0)
