Issues with MFnMesh object
jonah_reinhart
jonah_reinhart
 In the documentation for MFnMesh::create it says:
Creates a new polygonal mesh given an array of vertices, edge and polygon connection data and sets this function set to operate on the new surface.
If parentOrOwner is kMeshData, then it doesn't appear to operate on the newly created mesh data. In the code I initially encountered the issue (which was C++) in I had to run setObject() to make my closestIntersection call work.
Som functionality seemed to work without doing that though, like checking the number of vertices.
I thought that maybe it was just something unique about the kMeshData use case, that the documentation didn't mention. But I did some testing, and MFnMesh has the tendency to return inaccurate information about the object it is set to.
I encountered this issue with Maya 2026.2 on Windows 11
Below is a simple example to show some of the odd behavior:
import maya.api.OpenMaya as om
points = om.MPointArray([
    om.MPoint(0, 0, 0),
    om.MPoint(1, 0, 0),
    om.MPoint(0, 1, 0)
polygon_counts = [3]
polygon_connects = [0, 1, 2]
mesh_data_obj = om.MFnMeshData().create()
mesh_fn = om.MFnMesh()
mesh_geom = mesh_fn.create(
    points,
    polygon_counts,
    polygon_connects,
    parent=mesh_data_obj
print("mesh_data:", mesh_data_obj.apiTypeStr)
print("mesh_geom:", mesh_geom.apiTypeStr)
print(mesh_fn.object().apiTypeStr)
print(mesh_fn.object().isNull())
mesh_fn.setObject(mesh_data_obj)
BurkhardRammner
I only 'know' the c++ API.
When you use the create method, you get 2 outputs. When MFnMesh was initialized with a MObject that was constructed using MFnMeshData, then you get:
1. the 'mesh object' as the return object
2. the 'mesh data', which you can output to the DG
When you then want to continue to do work with the result, you got to set a MFnMesh to the 'mesh object'.
Thats the only really save way to do it.
jonah_reinhart
Yes, you can see that in the example I provided. After setObject it returns the expected thing, but the behavior prior to doing that is somewhat mixed.
The question is whether this is intended behavior, and the documentation is inaccurate, or if this is a bug.
BurkhardRammner
No AD employee will tell you. Its unpredictable and the only save way is to reset the function set to the resulting mesh object.
