Incorrect Python Joint Creation
shomari.rivero65CK4
shomari.rivero65CK4
This function creates a straight joint chain emanating from the origin.
It is working, although all the joints are being created from the origin.
How would I adjust this function so they are created normally in a hierarchy ?
def createSimpleSkeleton(joints): # joints = # of joints to create
   cmds.select(clear =True)
   bones = []
   pos = [0,0,0]
   for i in range(0, joints):
  pos[1] = i * 4
  bones.append(cmds.joint(p=pos))
  cmds.select(bones[0], replace = True)
 createSimpleSkeleton(4)
Kahylan
Hi!
Your select command was always reselecting bones[0] instead of bones[i]
    has positional attribute 'joints' which needs an integer to specify the number of joints created
    bones = []
    pos = [0,0,0]
        pos[1] = i * 4
        cmds.select(bones[i], replace = True)
But also, the joint command automatically selects the joint that is created, so this line is obsolete unless you are doing something else in your loop afterwards:
    bones = []
    pos = [0,0,0]
        pos[1] = i * 4
I hope it helps!
