How to set RGB color for Drawing Overrides with python
I did not manage to find a way to change the RGB color for my controllers via a pyhton script.
This only enables RGB, but I also found that the slider still reacts as if the mode was in Index
cmds.setAttr("controllerShape1.overrideRGBColors",1)
Is there a way to do this ?
Cheers
MF
cheng_xi_li
Autodesk Support
Autodesk Support
it should be something like
setAttr "lambert1.color" -type double3 0.5 0.5 0.5 ;
in Python version.
Yours,
Li
Thanks!
I meant for the Drawing Overrides but thanks to you I found the attributes.
I found the attribute overrideColorR and so on.
def setRGBColor(ctrl, color = (1,1,1)):
    rgb = ("R","G","B")
    cmds.setAttr(ctrl + ".overrideEnabled",1)
    cmds.setAttr(ctrl + ".overrideRGBColors",1)
    for channel, color in zip(rgb, color):
        cmds.setAttr(ctrl + ".overrideColor%s" %channel, color)
This should be the accepted answer, as the one that's accepted is wrong.
Yes you are right changed the solution.
