How to run python 3 script in python 2.7 in maya
yadavchandrabhan59
Message 1 of 10
yadavchandrabhan59
I have a script of software bridge cascaudour but it wasnt work on my maya 2020 version. I have attched script please suggest how to run or work on this.
Replies (9)
Message 2 of 10
jmreinhart
I don't have Maya 2020 installed on my machine so I can't test this myself but you could try adding some code to the top of the script to import the "future" module which will allow some python3 functionality to be used in python2.
If that doesn't work you modify the code based on what is not working (fixing syntax differences and stuff).
Or you could upgrade to windows 2022 where python 3 is standard.
Message 3 of 10
yadavchandrabhan59
how can I modify the code based on what is not working (fixing syntax differences and stuff) I dont know coding can you help me with
Message 4 of 10
jmreinhart
When you run the code do you get errors? If so you can use info like this: https://portingguide.readthedocs.io/en/latest/ to help you make the changes necessary to work in Python3.
If you're not getting errors then you'll need to manually check through the code for any syntax whose behavior would have changed between py2 and py3 (you can refer to that same link to know what to look for).
Message 5 of 10
yadavchandrabhan59
I have tried this with chat gpt several changes but it was not working....
Message 6 of 10
jmreinhart
When you try to run the code, are you getting errors? or are you getting the incorrect result?
Message 7 of 10
yadavchandrabhan59
The script I have attached above when script run correcting there was installing window pop up automatically and now when I run script there was an error written in lower tab syntax error exactly
Message 8 of 10
jmreinhart
What is the error message that it is giving you?
Message 9 of 10
yadavchandrabhan59
import maya.app.general.executeDroppedPythonFile as myTempEDPF
myTempEDPF.executeDroppedPythonFile("C:/Users/CHANDRABHAN/Downloads/maya_casc_installer.py", "")
del myTempEDPF
# Error: SyntaxError: file C:\Program Files\Autodesk\Maya2020\Python\lib\site-packages\maya\app\general\executeDroppedPythonFile.py line 66: invalid syntax #
Message 10 of 10
jmreinhart
So the area around line 66 looks like this
try:
    #python2
    reload
except:
    #python3
    from importlib import reload
I don't have 2.7 installed on my computer so unfortunately I cannot test it myself, but  you should be able to remove that section completely since reload is a standard part of python 2.
