Announcements
How to rotate or translate a MRenderItem in an MGeometry ?
In a maya plugin (c++), I have an MPxLocatorNode using a MPxGeometryOverride.
In the updateRenderItems function, I am creating MRenderItems and in the populateGeometry function, I am adding geometry to these renderItems.
Is there a way I can rotate or translate a renderItem without touching all the vertices I assigned to it ?
Thanks !
cheng_xi_li
Autodesk Support
Autodesk Support
You can use MRenderItem::setMatrix to apply a world matrix to it. You can do translate and rotation in the world matrix.
Yours,
Li
Oh, indeed ! Rtfm 🙂
Thanks !
negow
I'm having trouble with this.
MRenderItem::setMatrix does operate in worldspace using MPxSubSceneOverride, but not MPxGeometryOverride. For example this here is a no-op, does nothing.
void MyNode::updateRenderItems(const MDagPath& path, MHWRender::MRenderItemList& renderItems) {
    const auto matrix = MMatrix::identity;
    for (int i=0; i < renderItems.length(); i++) {
        MRenderItem* item = renderItems.itemAt(i);
        if (!item) continue;
        item->setMatrix(&matrix);
It can be reproduced by putting this into the geometryOverrideExample1.cpp example in the devkit, tested in Maya 2020.
Any matrix I set is relative the DAG node transform itself, not worldspace. Is there a way to fix this, other than involving an inverse matrix?
