How to return to UV after selecting the face.
243202504
Message 1 of 8
243202504
I know how to return vertices after selecting faces.
cmds.polyInfo(fv=1)
Usually, a face consists of 3 or 4 vertices.
However, when I select a face, in the UV interface, the index corresponding to the UV is completely inconsistent with the index of the vertex. For example, I selected a face.
select -r low3.f[469] ;
This face consists of 4 vertices.[u'FACE 469: 441 448 446 444 \n']
but i want get the uvCorrdinate. The 4 UVs on this surface are
select -r low3.map[863] ;
select -r low3.map[865] ;
select -r low3.map[864] ;
select -r low3.map[866] ;
I want to know how to get the index of these UVs through python,thx~
Replies (7)
Message 2 of 8
243202504
i found a way, use cmds.selectType,when i select a face ,use this commend,i can turn face to uv~
Message 3 of 8
243202504
this is wrong!
Message 4 of 8
Rourker27
I found this thread:
https://forums.cgsociety.org/t/convert-selection-to-uv-w-python/1366967/5
and from that I believe this code will do what you need:
import maya.cmds as cmds
cmds.select(cmds.polyListComponentConversion(tuv = True))
selectedUVs = cmds.polyEditUV(query = True)
print(selectedUVs)
Message 5 of 8
243202504
yes, i use this commend and got them. i mean the uvs.
but cmds.polyEditUV(query=True) got a list was not what i need.
i use cmds.ls(sl=1)
but here has a new problem , the list i got  length is not 4 is 3.
like that pic
u'pCube1.map[10,11]'
if i want got all 4 number ,I know that using the powerful data processing function of python can finally get the names of these 4 UVs, but are there any commands that can be used in Maya to get them quickly?
pCube1.map[3] ,pCube1.map[11] ,pCube1.map[1] ,pCube1.map[10]
not  [u'pCube1.map[1]', u'pCube1.map[3]', u'pCube1.map[10:11]']
Message 6 of 8
243202504
i use cmds.ls(sl=1)
like that pic
Message 7 of 8
243202504
i know what that[0.625, 0.0, 0.625, 0.25, 0.875, 0.0, 0.875, 0.25]
thats what i need ,the uv Coordinate
Message 8 of 8
243202504
