How to make Ipython, mayapy and Python27 binary live together on Windows 7 pro
I am facing a problem of conflicting lib in Python 2.7, IPython and mayapy.
I am on Windows 7 professionnal that is 64 bit system. If my readings are corrects about Maya 2016, the binary of Python27 in site-packages is a 32 bit version. That makes numpy not working in the same build inside maya or outside (Ipython on Python 2.7 64 bits).
My question is : Do you have any workflow to manage this ? or any advice on what i can do to get numpy inside Maya ?
What i found on the net is not clear.
Thank you.
vijaya.prakash
Did you go through the following forum post? here the post is clearly mentioned how to get numpy working inside Maya.
http://forums.autodesk.com/t5/maya-programming/guide-how-to-install-numpy-scipy-in-maya-windows-64-b...
