How to do vector diagram in python script?
2368457978
2368457978
Hi, do you know how this clickable vector diagram is made? Is it ps or Python?
jmreinhart
cmds.window()
cmds.columnLayout()
cmds.iconTextButton(image1 = 'bowlCurveProfile.png')
cmds.showWindow()
Also here is the script  I used to find the name of the icon maya uses.
try:
  from PySide2.QtCore import *
  from PySide2.QtGui import *
  from PySide2.QtWidgets import *
  from PySide2 import __version__
  from shiboken2 import wrapInstance
except ImportError:
  from PySide.QtCore import *
  from PySide.QtGui import *
  from PySide import __version__
  from shiboken import wrapInstance
import maya.cmds as cmds
import maya.mel as mel
import maya.OpenMayaUI as omui
class basic_ui(QWidget):# Create a class that inherits from the QWidget class
    def __init__(self, *args, **kwargs):#initialize function
        super(basic_ui, self).__init__(*args, **kwargs)
        # Create the needed variables
        # Get the main window as a widget
        omui.MQtUtil.mainWindow()
        ptr = omui.MQtUtil.mainWindow()
        mainWindow_widget = wrapInstance(long(ptr), QWidget)
        self.mainWindow_widget = mainWindow_widget
        #Parent widget under Maya main window
        self.setParent(mainWindow_widget)
        self.setWindowFlags(Qt.Window)
        self.setObjectName('iconPrinter')
        #Delete the UI if an instance already exists
        try:
            child_windows = mainWindow_widget.findChildren(QWidget)
            for widget in child_windows:
                if widget is not self:
        	        if widget.objectName() == self.objectName():
    					widget.close()
    	except:
    	    pass
        #Set the object name, window title, and window size
        self.setWindowTitle('Icon Printer')
        self.setGeometry(50, 50, 250, 150)
        self.initUI()
    def changeEvent(self,event):
        pass
    def closeEvent(self,event):
        pass
    def initUI(self):
        # Create the main layout
        self.window_layout = QVBoxLayout()
        self.setLayout(self.window_layout)
        self.iconList = QListWidget()
        self.window_layout.addWidget(self.iconList)
        self.populateIconList()
    def populateIconList(self):
        for icon in cmds.resourceManager(nameFilter='*') or []:
            newItem = QListWidgetItem(icon)
            self.iconList.addItem(newItem)
            newItem.setIcon(QIcon(":/" + icon))
basic_ui().show()
Thank you. I found that this script can't copy the icon name. It would be better if it could be copied.
