How to configure Visual Studio Code for Maya 2019?
g2m.agent
Message 1 of 9
g2m.agent
I want to write some script with vs code, but it kept reminding me:
Unable to import 'maya.cmds' pylint(import-error)
why??
I spent hours searching the Internet and still had no answer ...
Windows 10 x64
Maya 2019 + devkit
Anaconda 2019.03 x64 (python2.7)
Visual Studio Code 1.35 (extensions: Python, MayaCode)
Replies (8)
Message 2 of 9
Boon_in_Oz
I have exactly the same problem, currently in Maya 2018. Here's a little more info from my case:
If I do ctrl+shift+p, "Python:Select Interpreter" and set it to mayapy.exe, Pylint appears not to work at all. No errors are underlined.
If I set it to a different python.exe (Python 2.7) it works, but it complains about all my Maya (and MaxPlus and pymxs in my Max scripts) imports.
Autocomplete works perfectly for me too. The problem is only with Pylint.
I have also tried
PYTHONPATH=C:\\Program Files\\Autodesk\\Maya2018\\Python\\Lib\\site-packages; ...
in an env file, pointed to by python.envFile in settings.json, but unfortunately I haven't found a way to verify that works at all.
Message 3 of 9
Did either of you sort this out? I also am exploring using VSC for Maya 2018...
Message 4 of 9
g2m.agent
Yes, I found a solution!
You need to install MayaCode and MayaPy two plug-ins, and then execute this mel command in Maya:
commandPort -n "localhost:7001" -stp "mel" -echoOutput;
Finally, right-click in vs code->Send Python Code to Maya!
Message 5 of 9
Abdelmolkmounir1917
Observer
Observer
Message 6 of 9
moiamy
Hi
Is there an update for Maya 2022 ? I have established communication between VSC and Maya 2022 with :
commandPort -name "localhost:7001" -sourceType "mel" -echoOutput;
But when I execute "Send Python code to Maya" I got this error :
Message 7 of 9
denis.chikalyuk
Hey, fellas! Just in case someone will search help for Maya 2022 solution, here it is.
Author of that extension suggested  next:
ok so one quick solution is to avoid using the -echoOutput when you init the commandPort
so instead of this
you can run just this
 and it works for me in latest Maya 2022.
Cheers!😉
Message 8 of 9
jaranalDB9F6
Removing echoOutput from the commandPort command in 2022 worked for me with sending Python over the commandPort, but for some reason MEL scripts always give a syntax error
Message 9 of 9
brian_mckee
I'm getting a similar error message:
I have tried both:
commandPort -name "localhost:7001" -sourceType "mel";
Maya 2023. Any Suggestions?
