Hi, I use Stingray material's MEL "shaderfx". It looks like no "silent" or "force" flag to use. Is there any other way? Thank you.
shaderfx
Options:
-sfxnode
Specify the dagPath of the ShaderfxShader you are working on
The -sfxnode has to be supplied with (almost) every other flag
Example: shaderfx -sfxnode "ShaderfxShader1" -start;
-start
Start ShaderFX and open node graph
-replaceUI
(internal) Replace the existing node graph UI with the graph of another dagPath
-nodeUI
(internal) Rebuilds the Attribute Editor when a node is selected in the ShaderFX node graph
-getNodeCount
Returns the total number of nodes in the graph (includes all nodes inside all groups)
-getNodeUIDFromIndex node_index
Returns the unique node ID of a shaderfx graph node with a certain index
This number will not repeat in the same node graph and remains the same for
the life time of the node during a single Maya session
Many node/connection commands need you to supply this ID so ShaderFX knows what node to work on
Example: $nodeUID = `shaderfx -sfxnode "ShaderfxShader1" -getNodeUIDFromIndex [nodex_index]`;
-listProperties node_uniqueID
Returns the names of all properties available on the node
Properties are similar to attributes, but they are not directly connection to an input/output socket
Example: string $props[] = `shaderfx -sfxnode "ShaderfxShader1" -listProperties [node_uniqueID]`;
-getPropertyType node_uniqueID name_of_property
Returns the value type of a property (e.g. bool, int, float, float4, string, stringlist, action, etc)
-getPropertyValue node_uniqueID name_of_property
Returns the value of a property
Note that from type stringlist we return the string items in the list as well as the active-item-index in an array
Example: string $note = `shaderfx -sfxnode "ShaderfxShader1" -getPropertyValue [node_uniqueID] "note"`;
-edit_bool node_uniqueID name_of_property new_value
Sets the value of a boolean property
Example: shaderfx -sfxnode "ShaderfxShader1" -edit_bool [node_uniqueID] [prop_name] true;
-edit_int node_uniqueID name_of_property new_value
Sets the value of a integer property
-edit_float node_uniqueID name_of_property new_value
Sets the value of a float property
-edit_float2 node_uniqueID name_of_property X Y
Sets the value of a float2 property
-edit_float3 node_uniqueID name_of_property X Y Z
Sets the value of a float3 property
Example: shaderfx -sfxnode "ShaderfxShader1" -edit_float3 [node_uniqueID] [prop_name] 0.0 1.0 0.5;
-edit_float4 node_uniqueID name_of_property X Y Z W
Sets the value of a float4 property
Example: shaderfx -sfxnode "ShaderfxShader1" -edit_float4 [node_uniqueID] [prop_name] 0.0 1.0 0.5 1.0;
-edit_string node_uniqueID name_of_property new_value
Sets the value of a string property
-edit_stringPath node_uniqueID name_of_property new_value
Sets the value of a string path property
Can be useful for setting texture path properties
This will remove the Maya Project Path from the provided string
-edit_stringlist node_uniqueID name_of_property active_index
Sets the active index of a stringlist (optionList) property
Please note that this does not change the contents of the list, only what list item is selected
-edit_action node_uniqueID name_of_property
Triggers an action
Actions are usually buttons
Example: shaderfx -sfxnode "ShaderfxShader1" -edit_action [node_uniqueID] "helpaction";
-edit_exposeGrp node_uniqueID name_of_property new_sorting_value
Some properties on embed inside groups can be made visible when the group node is selected
This integer controls the order in which these properties are listed in the group node UI
A value of 0 will hide the property from the group
Example: shaderfx -sfxnode "ShaderfxShader1" -edit_exposeGrp [node_uniqueID] [prop_name] 1002;
-addNode node_type_id
Adds a new node of the supplied type (integer) to the graph
The node_type can be queried by name with: -getNodeTypeByClassName
Returns the unique ID of the newly created node
Example: $colorClassType = `shaderfx -sfxnode "ShaderfxShader1" -getNodeTypeByClassName "color"`;
$newColorNodeUID = `shaderfx -sfxnode "ShaderfxShader1" -addNode $colorClassType`;
-deleteNode node_uniqueID
Deletes a node or group from the graph
-addGroup name_of_group
Adds a new group node into the graph
Returns the unique ID of the group START node
Example: shaderfx -sfxnode "ShaderfxShader1" -addGroup "Texture Map-Hw Shader Nodes-Textures.grp";
-getGroupEndUID grp_start_node_uniqueID
Returns the unique ID of the group END node when providing the unique ID of a group START node
See -isGroupStart for more information on groups
-getGroupUID node_uniqueID
If a node is embed inside a group, this will return the unique ID of its group START node
Please note that this group START node may itself be embed in other groups
-isGroupEnd node_uniqueID
Returns true if the node is a group END node
-isGroupStart node_uniqueID
Returns true if the node is a group START node
Groups are made up out of two nodes that encapsulate the group: A Group Start and End node
While traversing the graph, you will come across these nodes a lot and you probably want to check for them
For example, if you are only interested in traversing the top level of the graph, you
will want to jump from a group end directly to a group start, instead of traversing the nodes inside the group
When you have a 'isGroupEnd' node, you can call -getGroupUID to find the group start node
When you have a 'isGroupStart' node, you can call -getGroupEndUID to find the group end node
The group START node holds the input sockets for the group
The group END node holds the output sockets for the group
This is important to realize, because you may want to get the inputs for a group and
if you query the inputs via -getSocketIndexByName (etc) on the group END node you may not
get the resuls you expected. You may first have to get the group Start node via -GetGroupUID
Example:
// We try to find the 'Diffuse Color' input socket on the Surface Shader node by starting at the 'Material' group:
$matUID = `shaderfx -sfxnode "ShaderfxShader1" -getNodeIDByName "Material"`;
$surfaceIndex = `shaderfx -sfxnode "ShaderfxShader1" -getSocketIndexByName $matUID "Surface Shader" 0 0`;
$surfaceNodeEndUID = `shaderfx -sfxnode "ShaderfxShader1" -getConnectedNodeID $matUID 0 $surfaceIndex 0 false`;
$isGrpEnd = `shaderfx -sfxnode "ShaderfxShader1" -isGroupEnd $surfaceNodeEndUID`;
if ($isGrpEnd == false) {print "ERROR! we were expecting to find a group end node for surface shader grp";}
$surfaceNodeStartUID = `shaderfx -sfxnode "ShaderfxShader1" -getGroupUID $surfaceNodeEndUID`;
$surfaceIndex = `shaderfx -sfxnode "ShaderfxShader1" -getSocketIndexByName $surfaceNodeStartUID "Diffuse Color" 0 0`;
-isGroupFromDisk node_uniqueID
Returns 1 (system node) or 2 (user node) if the node is a group node that is loaded from disk
Users may also create group nodes to organize their graph that
are stored only in the scene and not on disk. It will return 0 in those cases
The node_id provided should be of the group START node
-makeConnection output_node_uniqueID out_socket_index input_node_uniqueID input_socket_index
Makes a new connection between an output and input socket on two nodes
-breakConnection output_node_uniqueID out_socket_index input_node_uniqueID input_socket_index
Removes a connection between an output and input socket on two nodes
-getNodeClassName node_uniqueID
Returns class name of the supplied node
-getNodeIDByName node_name
Returns the unique ID of the first node found with the supplied name
Note: ShaderFX does not enforce unique names per node. This is up to the user to control
Internally ShaderFX relies on the unique ID to distinguish nodes from each other
-getSettingNodeID ui_name_of_setting
Returns the unique ID of the first node found that contributed a 'setting parameter' into
the ShaderFX Settings panel in the Attribute Editor
-getAttributeNodeID ui_name_of_attribute
Returns the unique ID of the first node found that contributed a 'Attribute parameter' into
the ShaderFX Properties panel in the Attribute Editor
-getNodeTypeByClassName name_of_class
Returns the type for a node class
When using '-addNode' ShaderFX expects an integer for the type of node you wish to create
But it is more intuitive to refer to node classes by name.
-selectNode node_uniqueID
Select a node in the node graph (graph UI needs to be open)
-getSocketIndexByName node_uniqueID socket_label socket_type name_index
Returns the index of a socket by searching for it by name
Socket_type=0 means search input sockets. Socket_type=1 means output sockets
name_index can be used if you know the node has multiple sockets with the same name and
you know you want the second, third, etc one
For example a Multiply node may have 2 input sockes called 'Value'.
To get the second one, you supply a name_index of 1
-getSocketCount node_uniqueID socket_type
Returns number of input sockets (socket_type=0) or number of output sockets (socket_type=1)
-getSocketName node_uniqueID socket_type socket_index
Returns name of an input or output socket
-getConnectedSocketCount node_uniqueID socket_type socket_index
Returns the number of sockets connected to an input or output socket
Note that even input sockets can have multiple incomming connections for some sockets
-getConnectedSocketIndex node_uniqueID socket_type socket_index connection_index skip_groups
Returns socket index of the socket connected to the supplied node and socket
If there are multiple connections to the socket, you use connection_index for the one you are interested in
connection_index should be 0 for the first connection
If skip_groups is false, we will not automatically jump inside group nodes
Instead, if a socket is connected to a group (end) node, we will return that group end node instead of
returning what is connected inside the group.
If you are interested in traversing the top-level of the graph only, and do not care what happens inside the groups then set this to false
Example:
$socketUID = `shaderfx -sfxnode "ShaderfxShader1" -getConnectedSocketIndex 303 0 3 0 false;`;
-getSocketType node_uniqueID socket_type socket_index
Returns the socket type string of the supplied node and socket
The returned string will be made up out of two parts: connectionType_valueType
Please note that the returned string may contain spaces. You can split the string by underscore
connectionType: This is usually the value you care about. It indicates the value the socket represents. E.g. int, float, float3 etc
valueType: indicates the internal (cached) value of the socket. For hardware shaders this is usually HwShader, but for 'Graph Nodes' this can also return bool, int etc.
'Graph Nodes sockets' are indicated with a 'v' drawn on their socket. They do not directly contribute code into the hardware shader, but instead allow for graph decisions to be made (e.g. what path to traverse)
Example: string $sType = `shaderfx -sfxnode "ShaderfxShader1" -getSocketType [nodeUID] 0 [socketIndex]`;
-getConnectedNodeID node_uniqueID socket_type socket_index connection_index skip_groups
Returns unique node ID for the node connected to the supplied node and socket
Example: $connectedNodeUID = `shaderfx -sfxnode "ShaderfxShader1" -getConnectedNodeID [srcNodeUID] 0 [srcSocketIndex] 0 false`;
-undoStack
(internal) adds a shaderfx change to the Maya undo stack
-loadGraph path_to_sfx_file
Loads a .sfx or .material graph. This replaces the current graph
Make sure you use forward slashes in your path
-loadSjsonMaterial stingray sjson material string
Loads a .material sjson string. This replaces the current graph
-swatchGeom geo_dagPath
Sets the geometry for the ShaderFX swatches
-swatchCamera cam_dagPath
Sets the camera for the ShaderFX swatches
-update
Rebuilds the shaderfx shader
Note that this re-generates the shader code but attempts to keep all attribute values
-manualUpdate bool
Sets manual computing of the graph true or false
When set to true, any changes in the graph (set properties, connections, etc) will not trigger the graph to update
-redraw
Redraws the node graph. UI must be open
-help
Display this help
-acquireMTextureFromSwatch node_uniqueID texture_size time textureName
Renders the swatch of the provided node into a Maya MTexture
Caller is responsible for calling release() on the MTexture when done with it
-renderSwatchToDisk node_uniqueID texture_size time texturePath
Renders the swatch of the provided node to a PNG texture
Note: Please make sure you have write access to the texturePath. E.g. Windows may block writing to root of C
Example: shaderfx -sfxnode "ShaderfxShader1" -renderSwatchToDisk [uniqueNodeID] 2048 0.0 "d:/MyTexture.png";
-renderSwatchToDiskUV See renderSwatchToDisk except then creates an UV-unwrapped image instead
-buildInfo
Display build information
-getHwShaderNodeID
Returns the unique node ID of the Hardware Shader node that is currently being rendered
Note that ShaderFX itself does not limit the graph to a single (hardware) shader
But this function will return the node that ShaderFX is currently rendering into the 3d view
-getHwShaderNodeRootGrpID
Returns the unique node ID of the top most group the Hardware Shader node that is currently being rendered is in
-getCode
Returns the hardware shader code generated for the viewport
-getTextureResolution node_uniqueID
Returns the texture resolution of a shaderfx Texture Component node
-initShaderAttributes
Triggers the default behavior (such as loading default graph) we see after creating a node via HyperShade or Assign menu
-setAdvancedMode
Enabled or disables Advanced mode in ShaderFX editor
-setUserPath
Set a custom path where shaderfx will look for user created group nodes and scenes (defaults to /HOME or /MyDocuments)
-createGroupNode
Create a new, empty group node and returns the group start node unique ID
-moveNodeInGroup group_startnode_uniqueID node_uniqueID
Moves a node that exists in the graph inside a group (use AddNode to add it into the graph first)
-SaveGroupNode group_startnode_uniqueID
Saves a group node to disk (Before saving, use -edit_string command to set the properties: classname categoryname submenuname)
