How to add a folding button to python?
2368457978
2368457978
Hello, everyone, my current script needs to manually input parameters before it can be executed. I want to know how to add a folding button that can be preselected? I looked for Python help documentation but couldn't find it. A button similar to my screenshot, I want to preset png exr tiff iff,67e73fdc11b5eeaa8ec3b5ae2984672.png2ac6dc0254d1de410209c001866cc4e.png
import maya.cmds as cmds import maya.mel as mel import os import shutil def get_texture_node(graph_node): mel_cmd = 'pgYetiGraph -listNodes -type "texture" %s' % str(graph_node) texture_nodes = mel.eval(mel_cmd) return texture_nodes def get_texture_path(texture, graph): mel_cmd = 'pgYetiGraph -node "%s" -param "file_name" -getParamValue %s' % (str(texture), str(graph)) path = mel.eval(mel_cmd) return path def set_texture_path(path, node, graph): mel_cmd = '''pgYetiGraph -node "{node_name}" -param "file_name" -setParamValueString "{path}" "{graph}"'''.format(node_name=str(node), path=str(path), graph=str(graph)) print(mel.eval(mel_cmd)) ################################################################################################ if cmds.window("YetiTool", exists=True): cmds.deleteUI("YetiTool") cmds.window("YetiTool", t="Yetitool", w=200, h=200, sizeable=True, mnb=True, mxb=False) cmds.scrollLayout('scrollLayout') cmds.columnLayout(adj=True) ################################## def set_yeti_texture_image(): all_yeti_nodes = cmds.ls(sl=1, s=1, dag=1) image_format = mc.textFieldGrp('imageformat', q=True, text=True) ## png exr tiff iff for node_name in all_yeti_nodes: tnodes = get_texture_node(node_name) if tnodes: for node in tnodes: texs = get_texture_path(node, node_name) tex_path = texs.split('.')[0] set_texture_path(tex_path + '.' + image_format, node, node_name) print ("Set scucessful: %s" % (tex_path + image_format)) cmds.textFieldGrp("imageformat", l='image', editable=True, cw2=(110, 110), cal=(1, 'left')) cmds.button(l='Replace image', c="set_yeti_texture_image()", bgc=(0.2, 0.4, 0.2), width=120) cmds.showWindow("YetiTool")
Kahylan
Hi!
Please when you post code use the codeblock (This symbol in your comment tool bar: </>) so we can just copy and paste the code instead of trying to guess the indentation levels and linebrakes... I could not get your script to run...
But what you are asking for isn't called a "Folding button" it is called a "Dropdown Menu"
What you want to do can be achieved like this:
window = cmds.window()
cmds.columnLayout()
cmds.optionMenu( label='Image Types')
cmds.menuItem( label='PNG' )
cmds.menuItem( label='EXR' )
cmds.menuItem( label='TIFF' )
cmds.menuItem( label='IFF' )
cmds.showWindow( window )
I hope it helps!
import os
import shutil
    return path
def ObjectCreation():
    currentValue = cmds.optionMenu("image_Format", query=True, value=True)
    if currentValue == "png":
        cmds.textField("png", e=True)
    elif currentValue == "exr":
        cmds.textField("exr", e=True)
    elif currentValue == "tif":
        cmds.textField("tif", e=True)
    elif currentValue == "iff":
        cmds.textField("iff", e=True)
    elif currentValue == "<UDIM>.png":
        cmds.textField("<UDIM>.png", e=True)
    elif currentValue == "<UDIM>.tif":
        cmds.textField("<UDIM>.tif", e=True)
    elif currentValue == "<UDIM>.exr":
        cmds.textField("<UDIM>.exr", e=True)
    elif currentValue == "<UDIM>.iff":
        cmds.textField("<UDIM>.iff", e=True)
    image_format = ObjectCreation()
        if tnodes:
            for node in tnodes:
cmds.window("YetiTool", t="YetiTool",
          w=460, h=600, sizeable=True, mnb=True, mxb=False)
cmds.rowLayout(nc=4)
cmds.optionMenu("image_Format", w = 140, label = "Select format")
cmds.menuItem( label='png' )
cmds.menuItem( label='exr' )
cmds.menuItem( label='tif' )
cmds.menuItem( label='iff' )
cmds.menuItem( label='<UDIM>.png' )
cmds.menuItem( label='<UDIM>.tif' )
cmds.menuItem( label='<UDIM>.exr' )
cmds.menuItem( label='<UDIM>.iff' )
cmds.button(l='Replacement format', c="set_yeti_texture_image()", bgc=(0.2, 0.4, 0.2), width=100)
Hello, I used the drop-down menu and defined parameters, but it still can't run. My script function is to replace the existing image format by selecting png, tiff and other image formats and then clicking Replace at the back. image_format = ObjectCreation (), ObjectCreation () should be the parameters I selected in the drop-down menu.35ca08729ce26f41b84982961466262.png
Kahylan
I couldn't really test it, since I've never used Yeti. Therefore I don't know how to set up a scene that I can test this in.
But I'm assuming the Yeti part of your code works and from the looks of your script you just need the dropdown menu to do some string formatting.
If you just need to get the value in the dropdown menu,you can do it like this, no additional readout function needed:
import os
import shutil
    return path
    image_format = cmds.optionMenu(imgFormat, query=True, value=True)
        if tnodes:
            for node in tnodes:
imgFormat = cmds.optionMenu("image_Format", w = 140, label = "Select format")
In your code, you for some reason referenced a textfield in your function "ObjectCreation" but you did not have any textfields in your UI. Also the way the textfield command works in edit mode is:
cmds.textField("Name of Textfield", tx = "Text you want to insert", e = True)
So your script was looking for the textfield with the name "png" (or whatever imageformat your dropdown menu had selected) instead of inserting the imageformat into a textfield. So if for some reason while running you also wanted to store your imageformat parameter in a textfield (I don't quite see the point since the dropdown Menu already is a clear indicator)
You would have to first create a textfield in your UI and then store the value to it correctly.
Something like this:
import os
import shutil
    return path
    cmds.textField(txtField, tx = currentValue, e=True)
    return currentValue
        if tnodes:
            for node in tnodes:
txtField = cmds.textField()
I hope it helps!
Thank you. The first method is what I need. Thank you very much.
