How Can I tell if a plug is dirty during "prepareForDraw"?
jmreinhart
Advisor Advisor
jmreinhart
So I have a custom locator that draws a subset of faces to make a deformable control using two inputs (a mesh, and a intArray of faces IDs). Like this https://vimeo.com/311008901
Ultimately I'm using this method to draw it:
drawManager.mesh(MHWRender::MUIDrawManager::kTriangles, draw_trianglePoints, NULL,NULL, &triangleIds);
Because I have to convert from facesIDs to triangle and vertex ids, I have stuff set up so that I cache the vertex ids I need to requery the positions of on each redraw, and I also put those positions into a non-repeating array and the "triangleIds" attribute contains the indices within that short list of positions that define each triangle I draw.
So "draw_trianglePoints" updates every time the mesh deforms, but "triangleIds" only updates if the topology changes or I change the value of the faceIds inputs. However during the "prepareForDraw" step I can't think of a way to avoid always re-querying "triangleIds" in case the value has changed, since I only have access to the DAG node being drawn. Does anyone have experience with optimizing custom locators for stuff like this?
muir.j
Not sure if this helps, but might be worth checking out the source for footPrintNode_GeometryOverride - it implements a variable called 'geometryChanging' that is updated in the compute node and then propagated through to the draw override class.
On a related note, if you are doing manipulators, the draw method also has limited access to variables so you have to pass the parent deformer class as a variable so you can get things while in the manip class.
jmreinhart
Unfortunately that's different than what I'm looking for. I found workaround where the user can manually reset a seprate attribute to tell the prepareForDraw method that the list of points I'm passing has changed. Unfortunately the speed increase was basically nothing, so I think I'm gonna have to shelf this MPxLocator and try a different approach entirely.
jmreinhart
Thanks to Matt Lefevre's method of using a forced compute and MObject.userNode to access the custom locators internal data I came up with a solution using setDependentsDirty. I've attached the .cpp with the solution. To summarize:
when the input to the MPxLocator changes it triggers setDependentsDirty which sets an internal attribute_dirty variable to true. During the prepareForDraw method we use MObject.userNode to access that attribute_dirty value to determine if we need to requery the MPlug or if the value already in the MUserData is still valid.
