Announcements
Hide row layout in a window
Hi everyone!
I'm programming a user interface window for a plug-in and I need to hide a row layout when I press an icon text button. Does anyone know how to do it?
Thanks!
You only have to call the rowLayout command (http://help.autodesk.com/cloudhelp/2017/ENU/Maya-Tech-Docs/Commands/rowLayout.html)
with -e  (for edit) and -visbile. Finally the name of the rowLayout:
rowLayout -e -visible false "NAME";
To read the value you have to specify -q (for query) instead of -e
int $visiblity = `rowLayout -q -visible "NAME"`;
global proc OnMakeRowInvisible(string $rl)
   rowLayout -e -visible false $rl;
global proc ShowWindow()
	string $sWindow = `window -title "TestWindow"
		-widthHeight 300 112`;
    columnLayout;
       rowLayout -numberOfColumns 2 MyRowLayout;
            text -label "TestA";
            text -label "TestB";
       setParent ..;
       string $cmd = "OnMakeRowInvisible(\"MyRowLayout\")";
       print $cmd;
       button -label "Make Invisible" -width 150 -command $cmd;
       button -label "Cancel" -width 150 -command ("deleteUI -window " + $sWindow);
    setParent ..;
	showWindow $sWindow;
ShowWindow()
Hope it helps you.
That was what I've been looking for all these days! Thank you very much! 😄
