Announcements
Error Setting UVs on MFnMesh
I have the code below, where I create a mesh, and try to set UVs
MFnMesh fnMeshCreator;
MObject meshMObj = fnMeshCreator.create(uniquePositionsList->Count, mesh->Triangles->Count, mPointArray, polygonCounts, polygonConnects, meshTransformObj); MFnMesh fnMesh(meshMObj); fnMesh.clearUVs(); if (fnMesh.setUVs(uArray, vArray) == MStatus::kFailure) { cerr << "Always comes in here" << endl; }
However, it always returns MStatus::kFailure when attempting to setUVs
Anyone know why?
Thank you
I think you have to create a uv set first.
MString uvSetName = MString("UVSet");
mesh.createUVSet(uvSetName);
mesh.clearUVs(&uvSetName);
mesh.setUVs(.., .., &uvSetName);
If this doesn't work you could try assignUVs(...)
Anything I do -- if I pass in MStatus object -- it is always setting it as MStatus Failure
I forgot this already, you must call assignUVs, this will connect the indices to the suitable uv's. When you have a unique uv coordinate for each vertex, then you can simply use the indices. You must also use the UV Linking Editor (select the object, then right mouse click->UV Set->UV Linking..) to choose your uv set (if you have mulitple uv sets)
fnMeshCreator.createUVSet(uvSetName);
fnMeshCreator.setCurrentUVSetName(uvSetName); // When you call this, then you don't have to assign the name to the following methods
fnMeshCreator.clearUVs(&uvSetName);
fnMeshCreator.setUVs(Us, Us, &uvSetName);
// Here you use the your polygon Count array and indices (polygonConnects) from the original method, this means for each vertex you create
// a unique uv coordinate. From this follow the Us and Vs array must have the same number like your vertex/point array!
fnMeshCreator.assignUVs(polygonCount, polygonConnects, &uvSetName);
Which method returns a Failed? In which method you execute your code?
MObject meshMObj = fnMeshCreator.create(uniquePositionsList->Count, mesh->Triangles->Count, mPointArray, polygonCounts, polygonConnects, meshTransformObj, &status);
if (status == MStatus::kFailure)
  cerr << "Mesh create error" << endl;
MString setName = "UVSet";
fnMesh.createUVSet(setName);
fnMesh.setCurrentUVSetName(setName);
fnMesh.getCurrentUVSetName(setName);
cerr << "Current setName after getCurrentUVSetName: " << setName.asChar() << endl;
if (fnMesh.setUVs(uArray, vArray, &setName) == MStatus::kFailure)
  cerr << "setUVs Error" << endl;
if (fnMesh.assignUVs(polygonCounts, uvIDs, &setName) == MStatus::kFailure)
  cerr << "AssignUVs Error" << endl;
Output:
setUVs Error
AssignUVs Error
As you can see no errors occured on Creation of the mesh -- and it seems it failed to create the UV set because the currentUVSetName is empty
Apparently doing this:
breaks it.
Instead doing:
MFnMesh fnMesh;
fnMesh.create(uniquePositionsList->Count, mesh->Triangles->Count, mPointArray, polygonCounts, polygonConnects, meshTransformObj, &status);
seems to not have errors in the setting of UVs anymore
