Help: Selecting mesh vertices through the Python 2.0 API
ejcarroll007
ejcarroll007
Hey everyone,
I'm trying to figure out how to select vertices through the Maya Python 2.0 API, instead of using the maya.cmds. I'm testing to see how much of a performance boost I can get when using the API.
Example of how I would normally approach selecting vertices in maya.cmds
import maya.cmds as cmds
vertices = [0, 1, 2, 3, 4]
vertex_select_list = []
for vertex in vertices:
    vertex_select_list.append("{0}.vtx[{1}]".format('pSphere1', vertex))
cmds.select(vertex_select_list)
Sample of my Python 2.0 API code for trying to select vertices. (This is what I scrounged up from how the internet does it)
import maya.api.OpenMaya as omapi2
sel = omapi2.MSelectionList()
sel.add("pSphere1")
dag, mObject = sel.getComponent(0)
mfn_components = omapi2.MFnSingleIndexedComponent(mObject)
mfn_object = mfn_components.create(omapi2.MFn.kMeshVertComponent)
mfn_components.addElements(vertices)
selection_list = omapi2.MSelectionList()
selection_list.add(mfn_object)
omapi2.MGlobal.setActiveSelectionList(selection_list)
The above code does not work as I get the following error...
# Error: RuntimeError: file <maya console> line 12: (kInvalidParameter): Object is incompatible with this method #
My 2 questions...
  1. In the error above, I get an incompatible error. But I'm not exactly sure what the issue is, as the MSelectionList.add() method requires an MObject. Which I am passing through when I used the MFnSingleIndexedComponent.create() method. Does anyone why I'm getting this error and what it means exactly?
  2. Is their a better/different way of selecting vertices through the Maya Python 2.0 API? I don't even know if this is the intended way of doing so.
-Eric
stuzzz
from maya.OpenMaya import * #import in this space for better visualisation
mesh = "pSphere1"
vertices = MIntArray()
indices = [4,2,1]
[vertices.append(x) for x in indices] #there might be a better solution for initializing a MIntArray with an tuple.
comp = MFnSingleIndexedComponent()
compObj = comp.create(MFn.kMeshVertComponent)
comp.addElements(vertices)
# we query the MDagPath of the mesh
dag = MDagPath()
sel = MSelectionList()
sel.add(mesh)
sel.getDagPath(0, dag)
# we then include a MSelection with the dag and its component(MObject)
sel2 = MSelectionList()
sel2.add(dag, compObj)
MGlobal.setActiveSelectionList(sel2)
stuzzz
To Answer your questions:
  1. The MObject you pass to the MSelectionList is a component type. MSelectionList::add expect a MObject of kMesh type (since you deal with mesh)
  2. You might have a great reason for selecting vertices with the api. I'm not sure there's a better way. As you can see you can use MObject as container for a selection. If you need to deal with such objects just attach them to some class functions (i.e MFnMesh, MItGeometry) instead.
ejcarroll007
Hello stuzz,
Thank you for the demonstration with the Python 1.0 API, it works great. But I was looking for the 2.0 haha
But it did help me find out what my issue was and it's a slight difference in the MSelection.add()
When I was looking at the documentation, I thought I couldn't add more than 1 argument. I had missed that I could add a tuple (MDagPath, MObject))
So modifying it like this now works!
sel.add("pSphere1")
selection_list.add((dag, mfn_object))
Thanks for the help!
-Eric
stuzzz
I'm glad it helped
