Getting a curve's mid point in worldspace?
jmalaska
jmalaska
I'm having difficulty finding a way to get a transform for the middle spot on a curve. I haven't gone as far as rebuilding the curve evenly with a ton of points evenly to get the middle, as that seems a bit overkill and I need to do this on thousands of curves. The commands curve and curvePoint don't seem to have the flags to get this midpoint.
Is anyone aware of a way to do this in one call?
zewt
If you want the point halfway along the curve, you need to convert the distance along the curve to the curve param, and then get the position of that param:
import pymel.core as pm
def go():
    # Get the MFnCurve for the shape node (do this however you want):
    node = pm.PyNode('curve1').getShape()
    curve = node.__apimfn__()
    # Get the curve param halfway along the length:
    length = curve.length()
    param = curve.findParamFromLength(length/2)
    # Get the world space position:
    p = om.MPoint()
    curve.getPointAtParam(param, p, om.MSpace.kWorld)
    # Sample output:
    loc = pm.createNode('locator').getTransform()
    pm.xform(loc, ws=True, t=(p.x, p.y, p.z))
go()
jmalaska
Thanks @zewt this is exactly what I was looking for. Cheers!
