Fragment shading malfunction during transformation
I'm experimenting with a simple C++ plugin which draws a shaded cube using a locator node with a geometry override. The shading is done by loading a fragment XML from file.
If "Consolidate World" is enabled, and I start transforming the locator node (e.g. by translating it), the shader stops working.
After loading it looks like this (see the fragment XML below):
After starting to translate the node:
The strange thing is that if I replace the mayaChecker in the fragment XML to mayaBulge, this doesn't happen.
Some more details:
On the plugin side there is a locator node with a geometry override which builds a cube in populateGeometry, and in updateRenderItems it loads a fragment XML from file, gets an MShaderInstance from Maya and assigns it to the cube render item.
The code for the latter:
const char* frag_name = fragment_manager->addFragmentGraphFromFile("my_fragment.xml").asChar();
my_shader = shader_manager->getFragmentShader(frag_name, "outSurfaceFinal", true));
my_render_item->setShader(my_shader)
The fragment:
<fragment_graph  name="TestFragment" ref="TestFragment" class="FragmentGraph" version="1.0">
    <fragments>
        <fragment_ref name="blinn_1" ref="mayaBlinnSurface" />
        <fragment_ref name="checker_1mayaTextureOutputTooutColor1" ref="mayaTextureOutputTooutColor" />
        <fragment_ref name="checker_1" ref="mayaChecker" />
    </fragments>
    <connections>
        <connect from="checker_1mayaTextureOutputTooutColor1.outColor" to="blinn_1.color" name="color" />
        <connect from="checker_1.mayaTextureOutput" to="checker_1mayaTextureOutputTooutColor1.input" name="input" />
    </connections>
    <properties>
        <float4x4  name="ViewProj" ref="blinn_1.ViewProj" semantic="viewprojection" />
        <float3  name="Pw" ref="blinn_1.Pw" semantic="Pw" flags="varyingInputParam" />
        <float3  name="Nw" ref="blinn_1.Nw" semantic="Nw" flags="varyingInputParam" />
        <float3  name="Vw" ref="blinn_1.Vw" semantic="Vw" flags="varyingInputParam" />
        <float3  name="Lw" ref="blinn_1.Lw" />
        <float3  name="HLw" ref="blinn_1.HLw" />
        <float3  name="diffuseI" ref="blinn_1.diffuseI" />
        <float3  name="specularI" ref="blinn_1.specularI" />
        <float3  name="ambientIn" ref="blinn_1.ambientIn" />
    </properties>
    <values/>
    <outputs>
        <struct name="mayaSurfaceShaderOutput" ref="blinn_1.mayaSurfaceShaderOutput" />
    </outputs>
</fragment_graph>
Please advise why is this happening and what can I do about it?
cheng_xi_li
Autodesk Support
Autodesk Support
Sorry for the delay. I think it is similar to a known issue which Pm value is unstable while moving the object. It appears that there isn't a workaround right now.
Yours,
Li
That's unfortunate, but thanks for the answer!
For future readers of this thread, the full code to reproduce this problem is here: https://github.com/zogi/maya-fragment-rendering-problem
Cheers,
Zoltan
andrei.alex
The problem occurs when the viewport uses OpenGL, it seems to work fine in DX11 mode. Unless your project(s) require OpenGL, maybe switching to DX11 could be a temporary workaround.
A.
