format float value precision with mel format commad
batarg
batarg
just making custom distance label with annotation node.
i need to format precision to get rid of extra values.. it will be great if it could be done within format command with syntax like in python (```"{:10.2f}".format(3.1415926535)```)
by default command  `format -s 3.1415926535 "^1s"` rounds to ```3.141593```
brentmc
The MEL format command is just for formatting strings, not numbers.
In MEL there are a couple of ways to do this:
The easiest solution is to just call Python from MEL.
float $value = 3.1415926535;
float $rounded = python("round(" + $value + ", 2)")
Otherwise, if you need a pure MEL solution you will have to use some lower level Math functions since there is no built-in round function.
float $dec = pow(10,2); // second arg is required number of decimals
float $rounded = floor($value*$dec+0.5)/$dec;
Brent McPherson
Principle Engineer
batarg
sadly that format command is so narrow in mel.
thank you @brentmc  for the tip! i will use your mel variant!
