Announcements
custom locactor compute function does not run on time
egoldid1
egoldid1
Hello, I wrote a locator node. and I think everything is normal. I have some attributes as input attributes and one mesh type attribute as output. When I change inputs, the compute function runs normally. but when I animate input attributes and hit the play button, the compute function does not run.
brentmc
Did you look at existing SDK examples of custom locators like the footprintNode?
Also, does your locator update if you disable cached playback or switch evaluation mode to DG?
Brent McPherson
Principle Engineer
egoldid1
hi, thanks. I checked it again and I think it is like footprintNode example.
Yes it worked when I switch to DG mode. but why? it is not good!!
I had written many locactor node before and I think I had no problem. Now I don't know why it is broken.
Also I have other issues. my locator shape also does not update when camera change:
https://forums.autodesk.com/t5/maya-programming/update-the-locator-node-shape/td-p/12401726
brentmc
If it works in DG mode but not with EM or caching enabled then it is likely it is an issue in your plugin.
Obviously, if you see the same issues in a sample plugin then it is more likely a bug in Maya.
Here are some whitepapers on EM and caching that explain how they different from normal evaluation which you might find helpful.
https://www.autodesk.com/support/technical/article/caas/tsarticles/ts/1cnB97uY8M2yjB1gyDHCuJ.html
Brent McPherson
Principle Engineer
