Flag -n or -name ignored for poly commands?
mspeer
Consultant Consultant
mspeer
Hi!
When using the following on a polygon object, shouldn't the name of the node be displayed as "new_nodename"?
(I tried several variations as -name, "new_nodename" and also some other poly commands and also in different Maya versions)
polyExtrudeFacet -tk 1 -n new_nodename;
kevinvandecar
Did you try it with single quote? For example 'new_nodename'
hope it helps
Kevin Vandecar
Developer Technical Services
Autodesk Developer Network
mspeer
Hi!
Yes i did, but this does not work at all.
// Error: polyExtrudeFacet -tk 1 -n 'new_nodename'; //
// Error: Line 1.27: Syntax error //
Does any variation work for you?
For creation it works like the following, but not on several edit commands.
polySphere -n new_nodename;
//or
polySphere -n "new_nodename";
