Thanks for the reply!
I already experimented with some of the options and the method you described is the fastest so far. The only caveat is that you really need to work with integers and pure edge/vert numbers here, not the full string name.
Just as a comparison, using only integer IDs it sorted a bunch of edges in about .5 seconds, but using full string names, the same code took about 10 seconds...
So if someone is going to repeat this in the future:
1. Use only integers and edge/vert IDs. Strings are extremely slow here.
2. Put edge IDs and its two verts IDs into three separate arrays so that their element number is in sync.
3. Pick a random edge (for me it's element 0 in the array)
4. Cycle through the remaining edges and compare (element $i in the cycle that starts from 1, because element 0 is our original edge)
5. Remember that you have two directions your "crawler" can go from the original edge. I solved it by comparing only one vert of the original edge in the first cycle, so I can get two "directions" in the first cycle, then compare both verts for all consecutive edges.
6. Remember to exclude already "discovered" edges and verts from the original arrays so that they are not interfering with the cycle. If you don't do that your "crawler" will go backwards sometimes. intArrayRemoveAtIndex works flawlessly.
7. Put all discovered edges into an array, combine it to string with " " as a separation string, and put this combined string into an array for storage.
8. All this code should repeat itself in a while loop until the original edge array is empty. On each while loop you will get your edge group and it will be stored in a string array as a string with separation string that can be converted to array whenever you need it.
All in all, this code is quite a trivial matter but sometimes it's simple tasks like that that are the most confusing for some reason.
