Failed to paste keys into Elfenliedtopfan5: time ranges not valid with given option
elfenliedtopfan5
elfenliedtopfan5
Good evening all i have this error that is driving me totally insane works fine when i manually try to do this but trying to get this to work with python is driving me crazy
below is a video of what i am doing,
for the life of me cant figure out why this is doing this here below is what i have
def load_idle_and_create_anim_layer(idle_anim_file, min_time_sprint, max_time_sprint):
    # Load the idle animation
    import_se_anim_file(idle_anim_file)
    # Allow a brief pause for the scene to update and for the idle animation to be fully loaded
    time.sleep(0.5)
    cmds.refresh()
    # Set the playback range
    set_playback_range(min_time_sprint, max_time_sprint)
    # Select 'Joints' and its hierarchy to ensure they are included in the animation layer
    cmds.select("Joints", hi=True)
    # Create the animation layer from selected joints
    anim_layer_name = create_idle_anim_layer()
    # Now that the layer is created with the selected joints, add the joints to the layer
    cmds.animLayer(anim_layer_name, edit=True, addSelectedObjects=True)
    # Attempt to paste keys to the newly created animation layer
    paste_keys_to_anim_layer(anim_layer_name, min_time_sprint, max_time_sprint)
    # Final UI refresh to ensure everything is updated
    cmds.refresh()
def create_idle_anim_layer():
    anim_layer_name = "Elfenliedtopfan5"
    # Check if the animation layer already exists
    if not cmds.animLayer(anim_layer_name, query=True, exists=True):
        # If it doesn't exist, create the animation layer directly with the name
        anim_layer_name = cmds.animLayer(anim_layer_name)
    else:
        # If it exists, ensure it's unlocked for editing
        cmds.animLayer(anim_layer_name, edit=True, lock=False)
    # The direct approach to make an anim layer current via script might be limited.
    # Therefore, focus on ensuring the layer is available and unlocked for the operations you need to perform.
    # Set the necessary attributes for the animation layer
    cmds.setAttr(f"{anim_layer_name}.rotationAccumulationMode", 1)
    cmds.setAttr(f"{anim_layer_name}.scaleAccumulationMode", 1)
    return anim_layer_name
def paste_keys_to_anim_layer(anim_layer_name, min_time, max_time):
    # Ensure the animation layer exists and is unlocked
    if cmds.animLayer(anim_layer_name, q=True, ex=True):
        cmds.animLayer(anim_layer_name, e=True, lock=False)
    else:
        print(f"Animation layer '{anim_layer_name}' does not exist.")
        return
    # Attempting to paste keys
    print(f"Attempting to paste keys into {anim_layer_name} from {min_time} to {max_time}")
    # Refresh and ensure UI updates have settled
    cmds.refresh()
    # The actual paste operation
    try:
        # Ensure the animation layer is targeted by making it the only selected object
        cmds.select(anim_layer_name)
        # Paste keys with the specified option
        cmds.pasteKey(animLayer=anim_layer_name, time=(min_time, max_time), option="merge")
        # Additional refresh after operation to ensure UI reflects changes
        cmds.refresh()
        print(f"Successfully pasted keys into {anim_layer_name}.")
    except Exception as e:
        print(f"Failed to paste keys into {anim_layer_name}: {e}")
i have tried to comment the parts best i can i not advanced with python only know little bit
but what i am doing here should be work but its failing with the error code
have checked maya createanimlayer documentation that is why i said about the script has limitations but not to this extent should still be able to copy keyframes
elfenliedtopfan5
Update it wont copy them to the timeline however it does copy the frames if i select the animlayer named elfenliedtopfan5 go to select objects and paste them in it does have the frames but it wont copy them via script for some reason.
urszula.lawecka6P3SY
Community Visitor
Community Visitor
I have the same problem and still haven't figured it out.
