Expressions - Setting attributes on many objects through a loop. Feedback pls...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am trying to make an expression that loops through a set of nodes and sets an attribute on each of them. I have been able to write something that does the trick. I have some questions, generally about cleanliness of code and efficiency. I'd love some feedback on this...
The expression does the following:
- Looks at a set of file nodes based on name. (The file nodes read image sequences.)
- Sets the frameExtension attribute on each of the file nodes so that:
- When we reach the end of the sequence, we loop back to the beginning.
- Each file node has the option to have a custom frame offset.
- The sequence can be slowed down by a given (integer) rate.
Here is the expression:
string $objList[5] = { "file1", "file2", "file3", "file4", "file5" };
int $offset[5] = { 0, 7, 11, 4, 18 };
$seqLength = 31;
$seqBase = 1;
$frameHold = 3;
$i = 0;
for ( $obj in $objList ){
$val = floor ( ( frame / 3) + $offset[$i] ) % $seqLength + $seqBase;
setAttr ($obj + ".frameExtension") $val;
$i += 1;
}My questions:
- The expression above has caused Maya to become unstable. I have a blank scene with only a few objects, file nodes, materials and this expression and Maya has been crashing much more than usual. What is causing it to become unstable?
- I have noticed that the attributes of the affected channels are not colored purple, despite the fact that there is an expression on those channels. Why is this? Is it because I am setting the attributes using setAttr rather than with the equals sign "=" ? What is the difference between the two? And how would I use the equals sign in a for loop?
- When doing a for loop (like above), is it better to use:
- "for ($a in $b)" and initialize $i before the loop.
- or
- "for( $i=0; $i<6; ++$i )" and use $objList[$i] in place of $obj.
- I tried running the expression below but I was given the error: "// Error: An execution error occured in the expression expression1."
string $objList[] = { "file1", "file2", "file3", "file4", "file5" };
$seqLength = 31;
$seqBase = 1;
$frameHold = 3;
for ( $i=0; $i<6; ++$i ){
setAttr ($objList[$i] + ".frameExtension") $val;
}- How do I get the length of a given array?
- When defining the string array, is it necessary to include the length inside the square brackets? Or can I leave this empty? Ex. "string $objList[] = ..."
- I was required to create all of the 5 file nodes manually in order for the expression to work. If I had many more nodes (10, 20 or 50) it would be tedious to set all of them up. So I am wondering whether it possible to create the file nodes also through code? I suspect I would need to do this through mel/python (not through an expression). Is this correct?
I thank you very much for your help!!
David
