Error: ValueError: file <maya console> line 6: No object matches name: .surfaceShader
baklayangoyo
Observer Observer
baklayangoyo
Observer
Observer
Hi i am not being able to get the name of the material while running this script. Its on a standar Surface
import maya.cmds
objTransform = "pPlane200"
objMesh = cmds.listRelatives(objTransform, shapes=True)[0]
objSe = cmds.listConnections(objMesh, type="shadingEngine")[0]
objMat = cmds.listConnections(objMesh, ".surfaceShader") or [0]
print(objMat)
and i get this error l any help?
Kahylan
Hi!
The surfaceShader is on the ShadigGroupNode not on the ShapeNode. You can find the ShadingGroup by searching for connections on instObjGroup[0] or your ShapeNode.
Also the "or [0]" would have caused you problems if there was no connection because it would have declared a list with one integer 0 instead of an empty list, which is what you normally want in situations like this.
import maya.cmds
objSG = cmds.listConnections("{0}.instObjGroups[0]".format(objMesh))[0]
objMat = cmds.listConnections("{0}.surfaceShader".format(objSG)) or []
print(objMat)
 I hope this helps!
baklayangoyo
Observer
Observer
Worked! Thank you !
