Duplicate skin cluster node will generate multiple bindPose nodes?
jiajun.coding
jiajun.coding
The according command is
cmds.duplicate("XXX_SCL", inputConnections=True)
Works well in most case but it make maya file size grows very large sometimes.
The worst case is from 100MB to 3GB.
In my finding, it will generate multiple bindPose nodes and only one bindPose node will connect to skinCluster? Why there are unused bindPose nodes generated?
Any ideas?
brentmc
Thanks. I'll pass this on to the team.
Brent McPherson
Principle Engineer
jiajun.coding
# Too many useless bindPose nodes will cause a large file size and very slow to save in disk.
def removeUselessBindPoses():
    removedAnyBindPose = False
    allDagPoseNodes = cmds.ls(type="dagPose") or []
    for poseNode in allDagPoseNodes:
        if "bindPose" in poseNode:
            connectionNodes = cmds.listConnections(poseNode) or []
            connectionNodes = list(set(connectionNodes))
    isUseful = False
    for connectionNode in connectionNodes:
        if cmds.objectType(connectionNode) == "skinCluster":
            isUseful = True
            break
    if not isUseful:
        cmds.delete(poseNode)
        removedAnyBindPose = True
    return removedAnyBindPose
This is my current solution to remove these generated but seems useless dagPose nodes named "bindPoseXXX".
