Announcements
Dots on mesh in Viewport
Message 1 of 9
I have compiled the provided apiMeshShape and in viewPort 2.0 I get the dots in the middle of each shape. Any idea how to remove these dots ?
Cubes
In addition to that, the shading is a bit strange (a standard lambert has been applied). As the attached picture shows it, the faces are not of uniform color (black at the bottom, bright at the top). How to have more flat colors on the faces like when I create a simple box using Maya's UI ?
Thanks !
Replies (8)
Message 2 of 9
RFlannery1
Maybe try from the menus "Display > Polygons > Reset Display"?  Does that make any difference?
Message 3 of 9
Unfortunately that didn't help. As you can see on the image below, I've added a standard polygon box that displays as I expect. So basically how to have the same effect on the "dotted" polygons than on the single cube ?
Message 4 of 9
did you try to set normals?
Message 5 of 9
Hi vlad_d,
This is something I looked at, but to be honest did not understand. Look at the apiMeshCreator code:
	pa.append( MPoint( -cube_size, -cube_size, -cube_size ) );
	pa.append( MPoint(  cube_size, -cube_size, -cube_size ) );
	pa.append( MPoint(  cube_size, -cube_size,  cube_size ) );
	pa.append( MPoint( -cube_size, -cube_size,  cube_size ) );
	pa.append( MPoint( -cube_size,  cube_size, -cube_size ) );
	pa.append( MPoint( -cube_size,  cube_size,  cube_size ) );
	pa.append( MPoint(  cube_size,  cube_size,  cube_size ) );
	pa.append( MPoint(  cube_size,  cube_size, -cube_size ) );
	normals.append( MVector( -normal_value, -normal_value, -normal_value ) );
	normals.append( MVector(  normal_value, -normal_value, -normal_value ) );
	normals.append( MVector(  normal_value, -normal_value,  normal_value ) );
	normals.append( MVector( -normal_value, -normal_value,  normal_value ) );
	normals.append( MVector( -normal_value,  normal_value, -normal_value ) );
	normals.append( MVector( -normal_value,  normal_value,  normal_value ) );
	normals.append( MVector(  normal_value,  normal_value,  normal_value ) );
	normals.append( MVector(  normal_value,  normal_value, -normal_value ) );
I don't understand why we have as many normals as points. For me a normal should be for a Quad or a Triangle, not for a point. So for a cube we should have 6 normals, not 8.
Any idea why this code has 8 normals ?
Thanks.
Message 6 of 9
RFlannery1
Ah, that explains the shading issue.  Normals are defined per vertex, not per face.  The normals are interpolated across the surface of the face.  This is important because otherwise, you would never get smooth shading.  (To see what I am talking about, make a poly sphere in Maya, and then deselect it.  Then in the viewport menus, select "Shading > Flat Shade All".  Notice how every polygon looks flat and every edge looks hard now?  That is because in "flat shade" mode, Maya does not interpolate the normals across the face.)
A cube is a special case.  You actually *want* each face to look flat.  To make that happen, the normals of all four vertices on a particular face must point the same direction.  When I said that normals are defined per vertex, that was actually not completely true.  Normals can be specified per-vertex-face.  With the cube, since each vertex borders three faces, each vertex can have three normals.  So a cube can have up to 24 normals (8 vertices * 3 faces at each vertex).
The code you showed only specified 8 normals.  So you are essentially getting soft edges instead of hard edges.  The picture below shows a cube with shared normals (8 normals) and one with separate per-vertex-face normals (24 normals).
I still have no clue about the dots on each face, though.
Message 7 of 9
Thanks for this clear explanation !
I still need to understand how to pass 3 normals per Vertex to the Maya Api.
Cheers.
Message 8 of 9
RFlannery1
I tried looking at the code in the example, but I couldn't figure out how it is processing the normals, or any of the data structure.  Sorry, wish I could help more.
Message 9 of 9
check MFnMesh::setFaceVertexNormals(...) or something similar
