Does Maya node editor support math.abs node ?
jiajun.coding
jiajun.coding
Someone tells me that I should use pow(x * x, 0.5)...
Kahylan
Hi!
Maya does not have a bouilt in Node that converts values to absolutes.
But you can use two multiply divides, both set to power, the first one power of 2, second one power of 0.5 to achieve the same effect. Or create an expression with the formula you already mentioned.
There are also 3rd party plugins that do this:
https://github.com/serguei-k/maya-math-nodes
I hope it helps!
jiajun.coding
Thanks, Kahylan.
Hope that Maya will support more generic math nodes in the future :).
etienne_allard
Hi!
There's now an "absolute" node in Maya 2024 (and some other new basic math nodes).
absolute node (autodesk.com)
Etienne Allard
Sr. Software Developer
