Different behavior of float and matrix data type
hello!
I've got a load of nodes with some custom attributes of type Boolean.
If i do
float $temop = `getAttr "object.boolattribute"`;
It comes out as 1, but if I'm using a matrix and I do
$myMatrix[0][0] = `getAttr "object.boolattribute"`;
It returns 0.
I don't understand but hopefully one of you does!
Actually it doesn't return 0, but it seems the cast will make bad stuff. Here is a solution, you explicitly have to cast it to a float or you write it before in another variable.
int $v = `getAttr pSphere1.visibility`;
matrix $m[3][3];
$m[0][0] = `getAttr pSphere1.visibility`;         // Wrong value
$m[0][1] = (float)`getAttr pSphere1.visibility`;  // Correct value
$m[0][2] = $v;                                    // Correct value
print $v;
print "\n";
print $m;
print "\n";
thanks!
