Delete unknown nodes in Python
Is there a way to delete unknown noeds from within Maya using Pyhton
#Something like...
for item in unknownNodes:
  if node.exists:
    delete node
print unknownNodes # []
haggi_master
import maya.cmds as cmds
cmds.delete(cmds.ls(type="unknown"))
rajasekaransurjen
unknownNodes=cmds.ls(type = "unknown")
    if cmds.objExists(item):
        print item
        cmds.delete(item)
ijdallas
Thanks, rajasekaransurjen, your code handles ALMOST all the unknown nodes.
It looks like there's another type, "unknownDag" that Maya also uses (eg for Mental Ray nodes if the plugin isn't loaded). I updated your code to include that type, and to unlock nodes before deleting them since Maya will refuse to delete any locked nodes:
unknownNodes+=cmds.ls(type = "unknownDag")
        print item
        cmds.lockNode(item, lock=False)         cmds.delete(item)
A recent Autodesk post also discusses a few more ways to remove unknown nodes, for example by using the Optimize Scene Size command: https://knowledge.autodesk.com/support/maya/troubleshooting/caas/sfdcarticles/sfdcarticles/Unable-to...
