Deform from a mesh to another
Hi all,
I was wondering how would I go about deform a mesh to another.
say I have 2 meshes.
The 1st one on the left and I want to deform this to the middle one.
However, I want to take in to account the nearby vertices so as to smoothly deform the whole mesh.
The 3rd mesh (on the right is what I would like to end up with more or less).
CheScreenshot from 2018-07-26 10-40-47.pngers
lauris4747
Are you referring to BlendShapes?
1 Create object
2 Duplicate it
3 Select original shift select child
4 In Animation tab Anim Deform > Blend Shape (Different Maya version keep blend shape options in different places)
thank you!
Basically, I was looking for smth along the lines of having a FFD like deformation cause with blend shapes
it source would linearly deform to destination mesh, hence the final shape would be identical to the destination which is not what I am after.
In contrast ,what I 'd like is some sort of FFD, maybe a lattice or similar applied to the source but instead of say having a lattice box (made of X control points to drive the source mesh deformation),
use the source's vertices as control points themselves.
I suppose if I could have a custom lattice of some sort made of the source meshe's vertices that would be an approach on it's own but is this possible.
