Customizing panel toolbars
micheleXGRRK
Observer Observer
micheleXGRRK
Observer
Observer
Hi there,
I would like to add a custom control on each panel's toolbar of the viewport in order to easily change the camera overscan. I've tried to search amongs maya mel scripts in the Maya path but was unable to find out the right procedure which is responsible for setting/modifyng the panel toolbar. Does anyone have hints and suggestions?
Using the "echo all commands" it seems like each icon makes a precise callback to a python function when pressed, but i'm puzzled.
Thanks in advance,
Michele
loncy888
Execute the MEL code. Each of the four default view panes adds a Custom menu.
	string $panel = "modelPanel";
	for ($i = 1; $i < 5; $i++) {
		if (!`panel -ex ($panel + $i)`) continue;
		menu -l Custom -p ($panel + $i) ($panel + $i + "CustomMenu");
			menuItem -l Print1 -c "print \"1\"";
			menuItem -l Print2 -c "print \"2\"";
		setParent -m ..;
I hope you found this helpful.
loncy
micheleXGRRK
Observer
Observer
thanks a lot! I'll try asap.
Thanks for your help
Michele
