Custom node to set vertex color based on geometry information
IW_09
535 Visites
0 Réponses
Message 1 sur 1
IW_09
Hi. I'm new to Maya and am still learning the basics, so apologies if this question is all over the place. I want to write a custom node that controls the mesh's vertex colour based on its geometric information (normal, curvature, displacement from another mesh, etc). I noticed that the
polyColorPerVertex command creates a node that connects to the mesh attribute rather than ColorPerVertex or ColorSet, so I tried to do the same. But when I try this in the compute method
# In initialize()
gattr = om.MFnGenericAttribute()
cls.mesh_obj = gattr.create("Mesh", "mesh")
gattr.addDataType(om.MFnData.kMesh);
gattr.keyable = True
gattr.readable = False
gattr.writable = True
# In compute()
mesh = data.outputValue(plug).asMesh()
mesh_fn = om.MFnMesh(mesh)
Maya raises the error "object is incompatible with MFnMesh constructor". I don't know if this is because I used MFnGenericAttribute instead of MFnTypedAttribute, so I switched to a deformer node (because it seems that MFnTypedAttribute in DependNode cannot be connected to InMesh/OutMesh of the shape node - yet another thing I don't understand). I can successfully create a mesh function set, so I tried
mesh_fn.setVertexColors(colors, indices) # colors: MColorArray, indices:MIntArray
which doesn't raise any error, but doesn't take any effect on the colour either. I'm not sure what to do now and would appreciate it if anyone can point me to the right direction.
0 J'aime
536 Visites
0 Réponses
Replies (0)
