curve param at Cvs
curve param at Cvs
egoldid1
curve param at Cvs
egoldid1
hi
how i can to get the Curve Param value at one CV(curve CV)?
robotProdigy
Normally, I would give a pointer on where to look, but I was bored while waiting on a render. I'm not sure if this works perfectly, or the exact way you need, but it may get you by if it's not. It gets the param value by getting the closest point on the curve from the passed in CV index. Then it gets the param from that using nice convenience methods in the Python API. In addition to returning the param value, it also returns the length, and closest point on the curve (in object space) to the passed in CV. If you want to update this function, you can see what other methods are available for MFnNurbsCurve in the developer docs
import maya.api.OpenMaya as om
def get_param_from_cv(curve_name, cv):
Returns the parameter, length, and closest point to the specified CV.
Args:
curve_name (str): Name of the curve
cv (int): The index of the CV in which to return the parameter value of
Returns (list[float, float, MPoint]): parameter, length, closest point on
curve in object space.
dgpa = om.MDagPath.getAPathTo(om.MSelectionList().add(curve_name).getDependNode(0))
curve = om.MFnNurbsCurve(dgpa)
cv_pos = curve.cvPosition(cv, om.MSpace.kObject)
closest_pnt, param = curve.closestPoint(cv_pos)
length = curve.findLengthFromParam(param)
return [param, length, closest_pnt]
# make a curve called curve1
param, length, pnt_on_curve = get_param_from_cv('curve1', 2)
print('param :%s' % param)
print('length :%s' % length)
print('pnt_on_curve:%s' % pnt_on_curve)
 -Paul
aldo.aldrich
Observer
Observer
Thank you!!!
