Confusing discrepancy between mesh.setVertexNormal and mesh.getVertexNormal
I'm trying to reproduce an issue where geometries loaded in maya have a zero-length normal. I try to create a shape and set the normal to 0,0,0, using "setVertexNormal" command, but when I query the MfnMesh using "getVertexNormal" command I don't see the same vector i.e. 0,0,0. The view port does show the effects of a zero-normal (black around the vertex) and I've tried deleting history, but no luck.
Please help.
Consider the code below:
api.py
import maya.api.OpenMaya as om
import maya.api.OpenMayaAnim as anim
# API interfaces ==========================================================================================
def getDag(id):
# add object path string a selection list
selectionList = om.MSelectionList()
selectionList.add(id)
# create empty dag path object
dagPath = selectionList.getDagPath(0)
return dagPath
def getMesh(id):
:param id:
:return: MFnMesh object
dag = getDag(id)
return om.MFnMesh(dag)
def createSpace(spaceName):
if spaceName == "kInvalid":
return om.MSpace.kInvalid
elif spaceName == "kTransform":
return om.MSpace.kTransform
elif spaceName == "kPreTransform":
return om.MSpace.kPreTransform
elif spaceName == "kPostTransform":
return om.MSpace.kPostTransform
elif spaceName == "kWorld":
return om.MSpace.kWorld
elif spaceName == "kObject":
return om.MSpace.kObject
elif spaceName == "kLast":
return om.MSpace.kLast
else:
def convertVector(mVec):
return [mVec.x, mVec.y, mVec.z]
def createVector(seq):
if len(seq)>3:
return None
return om.MVector(seq)
main.py
import api as api
#create
shapeId = "myTestSphere"
cmds.polySphere(name="myTestSphere",radius=1.0)
mesh = api.getMesh(shapeId)
#set
badNormal = api.createVector([0.0, 0.0,0.0])
space = api.createSpace("kPreTransform")
mesh.setVertexNormal(badNormal, 1,space=space)
#query
mesh = None
spaces = ["kTransform","kPreTransform","kPostTransform","kWorld","kObject"]
for spaceType in spaces:
space = api.createSpace(spaceType)
print mesh.getVertexNormal(79,False,space=space)
Correction:
The vertex is 1 for both set and get, so ... the main.py script is
#create
#set
badVertex = 1
mesh.setVertexNormal(badNormal, badVertex, space=space)
#query
mesh = None
print mesh.getVertexNormal(badVertex, False, space=space)
And the output is
(0.126539, -0.987692, -0.0919362)
I may finally understand what is actually happening. In order to reproduce the case I was seeing where a vertex's normal vector was 0,0,0, I took a cube and took four vertices of the same face and snapped them together. In such a case the vertex normal is [0,0,0].
In the test case I tried to make by setting the normal to 0,0,0 directly, I"m guessing that maya doesn't really change the true shape normals? It seems to know to draw that normal as if it were 0,0,0, perhaps like a normal map mapping to 0,0,0.
Is that correct?
