Condition command and specifically the dependency flag.
Message 1 of 1
Morning!
Querey for the day.
What can be put into the dependency flag of the condition command?
so far I am sure that you can use the events or conditions section of the scriptJob flags.
I want to know if I can use any custom ones like say when a specific attribute changes like scriptJob does.
quick run through
condition -initialize -d idle -s "MoP" ifItsTrue;
global proc int MoP()
int $swapSpace = `getAttr LeftArm_poleVector_CTRL.SwapSpace`;
if ($swapSpace == 1)
return(true);
else
return(false);
Right now Im using the IDLE dependency but why cant maya have a event or condition to check for an attribute change?
Update, used an expression dependency and it put it into an infinite loop.
LeftArm_PoleVector_CTRL.CurrentSpace=LeftArm_PoleVector_CTRL.SetSpace
This worked, not as I wanted but it still worked, and its not a standard condition or system event. So there must be a way to basically watch one attribute I just haven't figured out how.
Replies (0)
