Change color of arrows for overflow menuitem
csarrazinS7UXX
csarrazinS7UXX
Hello, is there a way to update the color of the arrows for the overflow menuItem? As you can see in the images provided, the arrows are very hard to see (in the red square).
jmreinhart
import maya.OpenMayaUI as omui
try:
  from PySide2.QtCore import *
  from PySide2.QtGui import *
  from PySide2.QtWidgets import *
  from PySide2 import __version__
  from shiboken2 import wrapInstance
except ImportError:
  from PySide.QtCore import *
  from PySide.QtGui import *
  from PySide import __version__
  from shiboken import wrapInstance
# Get the main window as a widget
omui.MQtUtil.mainWindow()
ptr = omui.MQtUtil.mainWindow()
mainWindow_widget = wrapInstance(int(ptr), QWidget)
children = mainWindow_widget.findChildren(QWidget)
# Iterate through the list to find the toolbar widget
for child in children:
    if isinstance(child, QToolBar):
        toolbar = child
        break
children[1].setStyleSheet("background-color: red;")
A bit hacky, but you can get the button using pyside and then set it's background color 🙂
