Cannot create connection to ShotGrid in Maya 2020.4
contactADYYR
contactADYYR
I cannot create a connection to ShotGrid within Maya2020.4
But connect via python outside Maya was fine.
These are the error
# Error: # File "C:\Program Files\Autodesk\Maya2020\bin\python27.zip\httplib.py", line 1123, in getresponse
# raise ResponseNotReady()
# ResponseNotReady #
I found a similar issue but the solution doesn't work on this case
https://forums.autodesk.com/t5/maya-programming/can-not-call-shotgun-in-maya-2020-4/td-p/10344408
Intel(R) Core™ i7-9750H CPU @ 2.60GHz 2.59 GHz
32.0 GB (31.8 GB usable)
Geforce GTX 1650
OS Windows 10 Pro 22H2
Build 19045.3208
Maya 2020.4
Really appreciate any help
Thank you!!
contactADYYR
OK turn off and on firewall and private network does solve the issue!!
