C# access? Build C++ plug-in with /clr switch? (use C++/CLI)
I would like to program Maya plug-ins in .Net managed code (C#/VB).
Similar to 3ds Max .Net SDK.
Or a more limited solution, where I have to write wrapper code myself.
Then once it works, if necessary for performance, would rewrite some or all in C++.
Is there any solution?
-- Steve
I'm not a .NET expert, but I think your main problem would be that there are no headers/bindings for C# or VB.
A Maya plugin is simply a .DLL file that exports two functions:
MStatus initializePlugin( MObject obj )
and
MStatus uninitializePlugin( MObject obj )
If you can create that in .NET then you might be able use it, but you still don't have C# / VB bindings to use Maya functions in your code.
I might be wrong though.
Maya usually has no problems using external frameworks, as long as it can be loaded through a DLL.
