Arnold and Renderman shaders created in C++ MPxCommand do not show in Hypershade
Standard Maya shaders created by their specific function set inside a MPxCommand plugin show up in Hypershade.
Shaders for Renderman and Arnold, which have to be  created by name with
MDGModifier dgMod;
MObject Shader = dgMod.createNode("aiStandardSurface",&stat);
do not show up in Hypershade, though the Arnold ones work fine. But they can't be edited in Hypershade.
I found -
"The command creates the ‘blinn’ node, connects its ".message" attribute to the ".shaders" attribute on the defaultShaderList1 node -
 this registers the node as a shader."
It said the mel shader command (and the Maya specific shader function sets) both create the node and add it to a shader list so the UI will recognize it as a shader.
In Maya 2017 defaultShaderList1 does not seem to exist. I can not find this node by name.
So how does one tell Maya that a shader node for an add on renderer is in fact a shader node so it will appear in Hypershade and the user can edit it?
I was able to use the MEL shaderNode command with the -asShader flag to create the new nodes with a given name.
Then back in C++ I search for the node by name and then proceed with setting it up.
And now they are all visible in Hypershade.
