API question: raycasting and closest point API?
Guys,
Im new to maya but not to cpp dev.
I looked thru the devkit and it seems pretty easy to make custom nodes. but i need some help finding some api classes
mainly: Does maya have a closest point and a raycast api for mesh surfaces.
I need this to implement a node that requires knowledge of surface collision and proximity
thank you in advance.
if this post needs to go someother place in the forum i will thank you
also i dont know what the better listsa nd forums are for serious tehnical questions. so if there are any better ones that i should look at, thanx
dy
Any takers?
Array of Point Positions -> Array of Direction Vectors -> Geometry => Array of positions
or
Array of Point Positions -> Geometry => Array of positions? or array of uv values or or or....
is there a way to do this with the MAYA API? Can someone point me to an example and to the necessary clssses
thank you
Hello dyon,
I don't know if Maya has a raycasting library.
I've been developing a set of custom libraries to do this called SceneEngine.
One of these libraries is ScEngRaytrace, which uses a KD-Tree implementation to find intersections between the surface and a ray.
The process is pretty simple. Create the array of vertices and faces, push that into the KD-Tree object and then intersect the KD-Tree with a Ray. If it intersects the mesh, then you get the intersected face id and the distance of such intersection.
The SceneEngine project also includes a Maya plugin you so you can use it as a base to know how to create the faces from your Maya mesh.
Hi Dyon,
Take a look at MFnMesh function set.
I hope that helps.
syntetik1
hi dyon, look at MFnMesh class. There are methods for closest point and also ray caster functions closestIntersection, allIntersections etc... Also I would recommend using Accelerator Param for speeding the ray cast. See more in the MFnMesh docs, there is even some example on this.
