I've been trying to follow a tutorial on making a USB cable. I have a lot of problems with the cord. Whenever I try to follow the tutorial and extrude along the curve, it goes funky. I've checked that I extruded from the start of the curve. Is there any solutions to this? Images included.
Solved by damaggio. Go to Solution.
Here's the same method but making a flat extrusion like a road using an EP curve for the road path and another EP curve at the base for the width of the road.
there's cubic and linear curves, I prefer linear because I can see each bend on the curve and hit the 3 key to smooth, but working in Cubic is also fine, see which one you like better.
You are not modeling in Nurbs, yeah I hate nurbs too, is just the curve is a nurbs, once you extrude you can choose Nurbs or Polys, also choose quads not triangles.
Ohh! Sorry to bother then that was such a beginners blunder! Thank you for the help too. Really appreciate it. Have a great day!
