Maya Modeling
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya modeling topics.
Weird Topology on mesh
3 REPLIES 3
skrishna2
523 Views, 3 Replies
 After I make a few adjustments my model goes crazy. Is there a reason for this?
3 REPLIES 3
brentmc
in reply to: skrishna2
You didn't give us very many details to work with...
Maya version, OS, what you are modifying would be good for starters. 😉
What happens if you turn off smooth mesh preview?
Brent
Brent McPherson
Principle Engineer
skrishna2
in reply to: brentmc
I apologize, I thought this was a an easily identifiable issue. The version I am using is 2018  and it's running on Windows. Here is a picture with the smooth mesh preview on of the Polaroid model I am working on. I am a new to modeling so I may have made some mistakes with the topology which may be why the mesh was acting up.
brentmc
If you repeat your modeling operation with smooth mesh preview OFF does the mesh still mess up?
Trying to figure out if the issue is with the mesh or a graphics card (display) issue?
The topology looks fine in your screenshots but you can always run Mesh Cleanup with Select Matching Polygons enabled to detect topology issues:
https://knowledge.autodesk.com/support/maya/learn-explore/caas/CloudHelp/cloudhelp/2015/ENU/Maya/fil...
To help further I would need the exact steps you were doing? e.g. I was extruding these polys and modifying the offset parameter...
Thanks.
Brent
Brent McPherson
Principle Engineer
