UV shell acting oddly
So I have UV'd my objects, cut in various places and everything was going fine until one of the UV sheels started acting oddly. The shell is identical to one of the others which is acting perfectly fine. What causes this and how can I fix the issue? Other than cutting down the middle and mirroring o.o
Issue: https://gyazo.com/21c4ba302ece9aface0d0f17b71ec649
Fovvl
Iam not seeing the problem, are you reffering that the the texture is upside down? May be you have it flipped. Check the icon "shaded" in UV editor it show you red and blue if its all blue then it is correct if there will be some reds you have them reversed, so you can flip it.
On the right hand side in the UV editor you can see two shells that look the same, one is perfectly squared which makes it much easier to texture and work with, the other is bent and therefore texturing would be a nightmare.
It turned out that the issue was the squared shell had an extra cut in it. I couldve also fixed the issue by using the UV->Straighten UV's option.
