03:59 PM
- Mute
- Permalink
- Report
I'm having a hard time fixing the topology of the shape I've modeled. I've gone ahead and circled the polygons that cut off my ability to add an edge loop. How do I merge the bent side into one continuous line, so that it becomes a quad again and an edge loop is able to be completed?
Should I use the multi-cut tool? How do I merge edges?
On the same note, here is what happens when I select the edge loop tool--a blue wireframe-y looking cage surrounds the model. I have "3" hit on my keyboard, which shows me the shape in smoothed form. Is the blue just showing me the outline of the original form? Or is it something different that I should be worried about?
Thank you.
Link copied
