Announcements
Texturing Issue - Black Sections
Message 1 of 15
Hi there,
I'm currently developing a basic game for a project I've got at college on which we will be using Stingray to build the game in.
I've created around 7 assets for one room, but I'm having issues with texturing with 2 objects. I unwrapped all of the UVs and sent the object into MudBox to texture. When I assigned the texture to the object in Maya I'm getting random black patches on certain parts of the object. I've checked the UVs and also even re-checked the texture in MudBox but everything seems to be fine. I have attached an image with what I mean.
Cheers'
George
Replies (14)
Message 2 of 15
n8skow
Do the black areas show in actual renders or just in the viewport?
Message 3 of 15
Hi there,
The black areas show in renders and view port.
Message 4 of 15
n8skow
Hmmm, possibly some bad geometry in there?
How many vertices are those pieces showing they have?
Are you able to post the scene file?
Message 5 of 15
When I imported the mesh into MudBox, there was no errors displaying. I've checked the UV's just in case anything was overlapping but couldn't find anything at all.
Not able to attach .ma files, forums won't let me. 😞
Message 6 of 15
n8skow
You'll have to zip the .ma file first.
Message 7 of 15
Ah, thanks!
Should be attached now.
Message 8 of 15
n8skow
The uploaded scene file seems to be a bit different, but I was not able to see the issues you having in the viewport.
Are you getting any error messages in the script editor?
Message 9 of 15
onSetCurrentLayout "Maya Classic";
file -f -new;
preferredRenderer -makeCurrent;
// Warning: file: C:/Program Files/Autodesk/Maya2017/scripts/startup/rememberViewportSettings.mel line 29: Active stereo does not work with Aero enabled. Active stereo has been disabled. //
// untitled //
doOpenFile ("E:/Games Dev - Year 2/Michael/Sringray_LevelUp/Assets/LivingRoom/Chair_01.ma");
file -f -options "v=0;" -ignoreVersion -typ "mayaAscii" -o "E:/Games Dev - Year 2/Michael/Sringray_LevelUp/Assets/LivingRoom/Chair_01.ma";addRecentFile("E:/Games Dev - Year 2/Michael/Sringray_LevelUp/Assets/LivingRoom/Chair_01.ma", "mayaAscii");
closeAllNodeEditors;
closeHypershade;
// Warning: line 2007: The default image may not be modified. Use the -i/image flag instead. //
// File read in 2.8 seconds.
commandPort -securityWarning -name commandportDefault;
// Error: line 1: Could not open command port commandportDefault because that name is in use. //
// AbcBullet v1.0 using Alembic 1.5.8 (built Dec 24 2015 17:28:19)
# pymel.core : Updating pymel with pre-loaded plugins: dgProfiler, mayaHIK, invertShape, CloudImportExport, curveWarp, ATFPlugin, hairPhysicalShader, ikSpringSolver, deformerEvaluator, retargeterNodes, shaderFXPlugin, renderSetup, GPUBuiltInDeformer, lookdevKit, Type, AbcBullet, modelingToolkit
// cgfxShader 4.5 for Maya 2017.0 (Jun 15 2016)
// AbcExport v1.0 using Alembic 1.5.8 (built Dec 24 2015 17:28:19)
// AbcImport v1.0 using Alembic 1.5.8 (built Dec 24 2015 17:28:19)
updateRendererUI;
select -r pCube1 ;
TextureViewWindow;
This is what is displayed in the script editor.
Message 10 of 15
n8skow
I'm not seeing any issues there...
Hmmm, what render engine does the issue appear in?
Also - what video card are you using?
Message 11 of 15
I'm using Stingray PBS, it only shows when I use Maya Hardware 2.0
My graphics card is Nvidia GeForce 950.
Strange thing is, it's only 2 models I'm having this issue with, all of the others have been completely fine.
Message 12 of 15
n8skow
Sorry I'm no help on this one...
Kind of looks like a z-sorting issue, does it show up once inside of your game environment or only in Maya?
Message 13 of 15
Just in Maya at the moment, haven't tried it in Stingray yet.
Message 14 of 15
alextar
Hey were you able to solve this issue at all?
I'm having the same problem
Message 15 of 15
cavescholar
You probably already tried reversing the normal but if not: Select one of the black faces and try
MESH DISPLAY>REVERSE ( screencap included where to find).
What happens when you switch to flat shading or flat lighting, does the problem go away?
If it does fix the display issue, then I think  it is just a display issue like an artifact. If it shows up correctly in game engine and in render, then again I think it is just a preview display artifact. The flat lighting and flat shading can be helpful, especially once you have advanced materials/lighting applied.
Good Luck!
