Messy vertexes easy solution?
I was wondering how id clean up all my vertexes, this looks like a mess. I look at other wireframes and they all have perfectly square quads. Help?
keith112
Hi Austin,
So there's no real quick solution to this. The best why I could suggest is by snapping your verts.
That will get you close.
  • Click the vert you want to move.
  • With the Move tool hold down C ( This will constrain your movements along curves)
  • MMD drag along a curve, while holding C ( the line between two verts)
  • Your vert will move along that line while sticking to the geometry you've built
Another way is to
  • Press W to go into your move tool.
  • Click one of the verts.
  • Highlight the axis on your move tool that you want to snap to. In your case I would click the y axis which you already have done in your picture.
  • Then hold down V and MMD a vert which you want it to share a close relationship to.
  • It will snap to it axis.
I hope this helps.
Keith
PS In the future try and keep these clean to save yourself the hassle of fixing it down the road when it's more complicated.
