Textures not showing in Maya. Any ideas?
metalheadmortal
Message 1 of 11
metalheadmortal
My textures are invisible and I have this red spots on my mesh, I think they are effecting the mess I dont know how to solve this does anyone know?
Replies (10)
Message 3 of 11
metalheadmortal
The texture is not visible I flipped the uv so do I have to re-wrap it?
Message 4 of 11
metalheadmortal
Update: Ok when I render it all of the textures are shown, but not in the perspective viewport
Message 5 of 11
mspeer
Hi!
Please show the rendered image or upload a scene-file.
Message 6 of 11
metalheadmortal
Here it is
Message 7 of 11
mspeer
Hi!
OK, now i understand what you are talking about.
It looks like these faces are not fully visible. My guess:
1. In the Mesh Node you have enabled Mesh Component Display -> Backface Culling ("wire" instead of "off"). (Faces are only fully visible from the front-side.)
2. The normals of these faces are reverted. (Because of that they were red in the UV Editor)
Select the faces and in Modeling Menu: Mesh Display -> Reverse Normals
If that's not the problem, please upload the scene-file.
Message 8 of 11
metalheadmortal
I dont thats the issue here is the scene-file
Message 9 of 11
mspeer
Hi!
You have transparency on your material:
Use a better transparency Algorithm like the new Alpha Cut:
in Viewport: Renderer -> Viewport 2.0 Settings / Hardware 2.0 Settings -> Performance -> Transparency Algorithm
or better, remove the Transparency from your material (lambert5) i don't see any benefit of this.
And some of your normals are reversed. Viewport: Lighting -> Two Sided Lighting (uncheck).
Message 10 of 11
metalheadmortal
Message 11 of 11
I have a similar problem and I get an error every time I open my Mayan 2017 program. And it is also with the textures and I have a student license
