split the mesh with the projected curve not working
HeavyMetalFox
Message 1 of 13
HeavyMetalFox
I am trying to project some curves on a a helmet (polygon) and split the mesh with the projected curve.
It works fine when I project the curves on the geometry but when I want "split the mesh with the projected curve" it only works with one projected curve (first one), when I try do the same for the second one, I get an error message and nothing happen (geometry is super clean) any ideas on how to fix that?
https://masterhotmail.tinytake.com/tt/NTA4MDEwNF8xNTk1NDQ2Mg
Replies (12)
Message 2 of 13
mihirsbcc
Step1. Project all the curves from any Aurthographics Viewport.
Step 2. Use Split Mesh with projected Curves Option box and choose Split and Detach Edges
Step3. Go to Mesh Menu and use splitpoly.JPG.
Message 3 of 13
HeavyMetalFox
Thanks for the info mihirsbcc 🙂
I tried you method with not much success, please let me know if I missed something.
https://masterhotmail.tinytake.com/tt/NTA4NDg5MF8xNTk3MTU1Nw
I also uploaded the helmet scene:
 https://drive.google.com/file/d/1zQ8gTxIWY08h7EjEwHK4hqvjJ3qkT5hM/view?usp=sharing
Message 4 of 13
mihirsbcc
If you want to slice the geo  then from the side view you draw EP curve straight line not circle, circle profile is looking down. That will not work.   If you rotate the circle and scale it down to a hole shape the it is going to create a hole through it.Draw EP curve not CV curve from the side view and use the same method. Let me knowepcurve position in redepcurve position in redsplit helmet.JPG
Message 5 of 13
HeavyMetalFox
Si drew 4 linear EP curves, did the projection from the right side, but still same issue with split mesh:
https://masterhotmail.tinytake.com/tt/NTA4NTAzMV8xNTk3MjAxNQ
Message 6 of 13
mihirsbcc
send me your email... i will send you a small clip
Message 7 of 13
mihirsbcc
here is a short clip
Split poly with projected curves
Message 8 of 13
HeavyMetalFox
It worked! I guess the trick is to do all the curves in one shot 🙂
Thanks alot for your help man.
Message 9 of 13
mihirsbcc
Message 10 of 13
HeavyMetalFox
running to the same issue again, same helmet but different curve position, any idea on how to overcome this?
https://masterhotmail.tinytake.com/tt/NTA5MzI2N18xNTk5MzQwNw
https://drive.google.com/file/d/1BkXlXJakMg-KL7Dd1FtBTb800ztNA4v2/view?usp=sharing
Message 11 of 13
mihirsbcc
The overlapping lines are confusing the projection.  will not work. Tested with parallel lines, needed scaling the lines wider , from the side view it worked. Since you are trying to cut straight lines you should use the multicut tool and draw straight cut. Faster and easier.
mmulticutmmulticut
Message 12 of 13
HeavyMetalFox
completely forgot about multicut!
Much thanks for you help sir.
Message 13 of 13
mihirsbcc
Is this what you rendered out?
