split the mesh with the projected curve not working
HeavyMetalFox
2,243件の閲覧回数
12件の返信
メッセージ1/13
HeavyMetalFox
I am trying to project some curves on a a helmet (polygon) and split the mesh with the projected curve.
It works fine when I project the curves on the geometry but when I want "split the mesh with the projected curve" it only works with one projected curve (first one), when I try do the same for the second one, I get an error message and nothing happen (geometry is super clean) any ideas on how to fix that?
https://masterhotmail.tinytake.com/tt/NTA4MDEwNF8xNTk1NDQ2Mg
解決済み
2,244件の閲覧回数
12件の返信
返信 (12)
メッセージ2/13
mihirsbcc
Step1. Project all the curves from any Aurthographics Viewport.
Step 2. Use Split Mesh with projected Curves Option box and choose Split and Detach Edges
Step3. Go to Mesh Menu and use splitpoly.JPG.
0 件のいいね
メッセージ3/13
HeavyMetalFox
Thanks for the info mihirsbcc 🙂
I tried you method with not much success, please let me know if I missed something.
https://masterhotmail.tinytake.com/tt/NTA4NDg5MF8xNTk3MTU1Nw
I also uploaded the helmet scene:
 https://drive.google.com/file/d/1zQ8gTxIWY08h7EjEwHK4hqvjJ3qkT5hM/view?usp=sharing
0 件のいいね
メッセージ4/13
mihirsbcc
If you want to slice the geo  then from the side view you draw EP curve straight line not circle, circle profile is looking down. That will not work.   If you rotate the circle and scale it down to a hole shape the it is going to create a hole through it.Draw EP curve not CV curve from the side view and use the same method. Let me knowepcurve position in redepcurve position in redsplit helmet.JPG
0 件のいいね
メッセージ5/13
HeavyMetalFox
Si drew 4 linear EP curves, did the projection from the right side, but still same issue with split mesh:
https://masterhotmail.tinytake.com/tt/NTA4NTAzMV8xNTk3MjAxNQ
0 件のいいね
メッセージ6/13
mihirsbcc
send me your email... i will send you a small clip
0 件のいいね
メッセージ7/13
mihirsbcc
here is a short clip
Split poly with projected curves
0 件のいいね
メッセージ8/13
HeavyMetalFox
解決済み
It worked! I guess the trick is to do all the curves in one shot 🙂
Thanks alot for your help man.
0 件のいいね
メッセージ9/13
mihirsbcc
0 件のいいね
メッセージ10/13
HeavyMetalFox
running to the same issue again, same helmet but different curve position, any idea on how to overcome this?
https://masterhotmail.tinytake.com/tt/NTA5MzI2N18xNTk5MzQwNw
https://drive.google.com/file/d/1BkXlXJakMg-KL7Dd1FtBTb800ztNA4v2/view?usp=sharing
0 件のいいね
メッセージ11/13
mihirsbcc
The overlapping lines are confusing the projection.  will not work. Tested with parallel lines, needed scaling the lines wider , from the side view it worked. Since you are trying to cut straight lines you should use the multicut tool and draw straight cut. Faster and easier.
mmulticutmmulticut
0 件のいいね
メッセージ12/13
HeavyMetalFox
completely forgot about multicut!
Much thanks for you help sir.
0 件のいいね
メッセージ13/13
mihirsbcc
Is this what you rendered out?
0 件のいいね
